Finding the right speaker
navi_1993
India
Budget 20k
I am looking for speakers for my 12ft * 14ft bedroom.
Wireless (may / may not be portable).
I prefer a balanced output (V and bassy output are complete No !! No !!)
I usually listen at 60% volume levels. (50% of the time, it is placed on my study table i.e. 1-5 to 2 ft distance)
The bedroom doesn't have any sound padding as such.
I already own a JBL Flip 1 and am looking for a fuller response.
Some preliminary search at whatHiFi.com led me to
Audio Pro Addon T5 and T 10 gen 2.
Budget 20k
If there is an option of building a good non-portable stereo system with in 20K, playing wireless, takes lil space on your study table, would that interest you?
If you can manage to lay hands on the Harman kardon sound sticks II, you will be very presently surprised.
Looks very stylish. Infact it won a red dot design award for its modern design, and is on permanent display in the museum of international design.
Sounds really awesome. Accepts 3.5 audio from any phone, and also has Bluetooth for wireless streaming. Comes with a sub with level setting, and you can increase or reduce the bass to your liking. It was my first hifi ever if I can call it that. And still have it me... absolutely love the sound quality despite having a dedicated stereo setup now.
Try and see if you can find it. You will not be disappointed. Cheers...
Hi again navi....
Was searching for these and found them on Flipkart for 15k. Out of stock on Amazon though. These are the version iii, and same as the ones that I have. Cheers....
A little new to setting up a HiFi system, I've spent most of my time with headphones.
Can anyone guide me to use and importance of amps.
Some links of text would be great knowledge booster for me.
(I don't know anything about speakers apart from a speaker which comes in one piece. Can u charged, connected to and used)
In short, an amplifier is a device that receives an input signal from set top box, TV, mobile, Blu-ray player, amplifies and send it to speakers..
Here is one link to understanding - https://www.techwalla.com/articles/the-differences-between-an-av-receiver-an-amplifier
Since you have a sizable budget, suggestion to build your hi-fi system..
This small amplifier, which can play MP3 files thru USB, has bluetooth too & should do all your needs - https://www.aliexpress.com/item/FX-Audio-M-200E-Nondestructive-Bluetooth-4-0-Support-USB-SD-Card-Hifi-MINI-Power-Amplifier/32817979852.html?spm=2114.search0104.3.1.zXNkgc&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10068_5430020_5410020_10307_10137_10060_10155_10154_10056_10055_10054_10059_100031_10099_5400020_10103_10102_10052_10053_10142_10107_10050_10051_5380020_10326_5390020_10084_10083_5370020_10080_10082_10081_10110_10175_10111_5420020_10112_10113_10114_10312_10313_10314_10315_10078_10079_10073,searchweb201603_16,ppcSwitch_4&btsid=2caa43b5-c22f-4ce5-976b-1ac3c7bd2076&algo_expid=de11259f-75ee-47f0-8b66-e92a13077160-3&algo_pvid=de11259f-75ee-47f0-8b66-e92a13077160
For speaker, consider this - Taga Harmony TAV-806S Surround Speaker Perfect match for TAV-806F, TAV-806C | eBay
Both the equip together, shouldn't cost you more than 20K.. But will make a great system..
1.
https://www.aliexpress.com/item/FX-A...6-e92a13077160
Has anyone ordered from this site and have -ve feedback (and got your refund in case of issues?)
2. Will the abv FX Audio M-200E amplifier drive Pioneer SP-FS52 floorstanders (130 w/ 6 ohms)?
If not, can anyone suggest some other amp within 10k for the abv FS?. Reading good reviews of Norge in this forum, preferably concerto 1000?
3. Can anyone suggest where i can audition sp-fs52 speakers or cheaper amp+spkrs in chennai?
sry for hacking the thread navi. Yet another novice!
1. https://www.aliexpress.com/item/FX-A...6-e92a13077160
If not, can anyone suggest some other amp within 10k for the abv FS? Reading good reviews of Norge in this forum, preferably concerto 1000?
sorrry for hacking the thread navi. Yet another novice!
~ y rnt ppl selling more of under 10k stuff here?:sad:
I have no experience with aliexpress.. But FM have ordered here without issues.. One FM (@drkrack) had issue with his SMSL AD18 amp, and the seller had asked him to bear the shipping charges to china.. After which he received the refund i guess.. You may send him a PM for more inputs..
It should comfortably drive them..
If Sub-out is a feature that you are not looking at, you can consider the FX-Audio M-160E for a lot less - https://www.aliexpress.com/item/FX-Audio-M-160E-Bluetooth-4-0-Digital-Audio-Amplifier-Input-USB-SD-AUX-PC-USB/32713031635.html?spm=2114.12010108.1000023.5.7d847a74QIHrI
Norge is stereo amplifier which doesn't have digital inputs, bluetooth, USB feature & remote control..Would be expensive then FX Audio..
Think SP FS 52 has reached the end of cycle.. Anyways, check with Decibel, dealer for Pioneer speaker in chennai..Contact | decibel - the art of sound | Home Theatre, Hi-Fi, Custom Installation, High End Audio, Multi Zone Installers Chennai, India
You can check different VFM offerings that are aval..
Bcoz the first hand stuff costs significantly higher, no one is selling it for under 10K :)
