For Yamaha 3066 receiver compatible speaker
awdhesh17
Hi All,
I have been using Yamaha 3066 AV receiver with the default speaker that came with the package since year 2014. I have got a new home theatre.
I want to ask is it possible to select better speaker in the same receiver? If yes Please advise which all speaker I can use with the same Receiver. My budget is limited to around 40K, since I also will have to spend on Projector. ( Please suggest for project too budget 1L). Thanks in Advance
