Dear all ..... I am going to try a 12" driver for my center channel. Ijust want to make this like an OB with a front baffle 2ft x 3ft size.
I will mount this 7" away from the front wall, behind the PJ screen.
Now the question is, should i make a simple front baffle? ( like the left model in the pic?)
Or....
Should I add the sides, top & bottom walls also? (shown in right pic)
I am asking this with an understanding that the purpose of a baffle is to separate the air in the front & rear of the driver.
Only a front baffle of that size is enough for this job? Or adding side walls make it better?
ADDITIONAL INFO:
I am not going to do an enclosure design.
I am not going to worry about any calculations or simulation.
Its just a blind try with a practically possible baffle size.
Or....
ADDITIONAL INFO:
