Good Speakers under 30000 Rs
sskcontrol
CHENNAI
Hi, Can someone suggest me a good speakers to listen both music and movie 50%-50%. I am planning to buy stereo amp to pair with bluray player and like to hear clear sound.
I assume floor standing speaker will give clear and big sound than bookshelf. Please correct me and suggest a best pair of speakers under 25000 or 30000 Rs
Get to Decibel, 21 Chittaranjan Road, Teynampet and audition the Q Acoustics Concept 20. They can order the mostly similar Q Acoustics 2020 for you if you don't walk out with the Concept 20 :)
ciao
gr
for your mentioned price , it will be very difficult to get tower speakers..
my suggestions is , buy q acoustics 2020i (rs.24000) or wharfedale diamond 121(rs.22,000) both are award winning speakers and i heard and owned ...excellent sound in my opinion..
for remaining amount , you can buy decent stand for better results..
or if you have shelf or racks , then try new dali zensor 3 for bigger sound for around your price..
-suresh babu
Floor-standers are good option if you have good space.... You can consider the Sonodyne Sonus 2605 FS for approx 30K price in Hifimart....
Try the same delaer Decibel.. I heard he deals with Sonodyne Active range of speakers..Check with him for Sonus range too....
If you are considering BS, there are plenty of options.... FM have already suggested the best models for your price....
You can try the dali lektor also. It gives you warm sound & detail sound suitable for listening to vocals in music/movies.
Consider usher s520 from Arn systems bangalore. they are book shelves but sound excellent. Google for many professional reviews.
Sid
Boston Acoustics A26, Pioneer SP-FS52 (Floorstanding speakers), Tannoy Mercury etc are available for prices within your budget however the final discerning factor will be your aural experience during demoing various speakers.
hi friends , need inputs regarding two wall mounted speakers. B&W M1 & Monitor Audio R90. Which would be better of for HT purposes for a midsize room. B&W is about 5k more expensive per speaker. Which of these offer better dynamic range as well as detailing. Do these offer better sound compared to VFM / cheaper alternatives like the sonodyne Genie 1 or Genie 2 for HT applications.
Or do the compact stand mounters like Q acoustics 2020i or PSB imagine mini trump these satellites in the dynamic performance purely for movies. Your suggestions are welcome & I hope to get some insights before auditioning these.
Thanks in advance
The key is to audition the speakers and make an informed decision. Refer to the specs and see the key differences in output, SPL levels, the range of frequencies emitted between 20hz - 20khz. The more the better spectrum and clarity in sound. The kind of drivers (speaker units) used..fibre, glass cone etc....There would be online reviews and videos posted over the internet by owners which will help further guide you....at the end of the day, it all boils down to what appeals to you in performance, appearance and ofcourse the budget.
