Got my new rdac kw and there is my review
santosh4
I got my new rdac kw and now i have connected the following:
Playing 24bit 192khz files
pioneer bdp 170 ->coaxial->rdac->NAD375BEE->PSB Image T5
The bass punch is breathtaking, I dint know the dac would make such a difference.
the Bass is very tight
and the treble is clean.
I compared it with my other set:
marantz 511->PSB IMage T5 + wahfedale sw 150 Sub
The distribution of instruments are clean but it lacks the punch that above config has its like melodies but not as thumping as the NAD.
Let me know your thoughts.
Now I am planning for B&W 805 Diamond so that my configuration would be :
marantz 511 ->B&W 805 Diamond + whafedale sw150.
Cheerss,,,
hi santosh
thanks for the review. arcam is a good brand and so definitely will be a good dac. but heard reviews that the sound isnt as balanced as it should be. also is it musical. was thinking of going for the rdac since its on special now that the newer model irdac is out
