Gpu for 4k@60 for movies only
annapl
PUDUKKOTTAI
i have htpc with gtx960 it can only max out 4k@30
if i change to 4k@60 the resolution returns back to 4k@30hz
should i change the gpu?
any minimum requirement gpu for 4k@60 for movies only i dont game @4k
my display supports 4k@60
What is your chain? Are you using an AVR in between your pc and your display? Can you force 60Hz on your display?
Also, it seems that the 960 has a dedicated hdmi 2.0 port. Can you try connecting your output chain to this port? You can refer the manual for the exact port if it has more than one HDMI out.
Ignore the forcing part. That's an option on the firestick. Can you please confirm if you are using the right cables (HDMI rated @ 18gbps at least) and also the lengths are not too long (less than equal to 15feet per cable)?
