Has anyone purchased from Talema India.
Well, i can't say about power transformers, but we have used current sense transformers from talema and the product is good and meets the specs.
know them from my previous job 5 years ago.They supplied us big toroidal transformers along with Toroid india, Salzer etc.
I bought 2 Talema trafo for my amp build. I havent tested yet. But heard it is good. I didnt do a direct purchase.
Badri
Yes talema transformers are very good and have some compact ones that can be mounted directly on the PCB.
Badri
How did you procure them? I tried contacting them but seems they don't sell retail quantities. Same goes for Salzer.
I ordered through RS componenets.
Nuvotem
This is what I bought.
5000 for a 225 VA trafo !! most diy people will not prefer even import of trafo comes cheaper than this ..
Telema india can get some good prices for common diy people i think we have many takers here .
I have done such adventures contacting some indian firms but nothing worked as individual .
I enquired shilchar for R-Core and Salzer for Toroid. From Salzer I think we can get trafo for a decent price. But will take time. But from shilchar its costly if the quantity is less. But reasonable when compared to other online sales. Soon I may buy 1 or 2 R-Cores from shilchar. And Shilchar is well regarded for its product.
Aluminum Amplifier Case, Aluminum Amplifier Case 01, Aluminum Amplifier Case 02, Cable TV Amplifiers
amp cabinets !! lets dream will be reasonable
get better trafo deals , i will just join for 1/2 pc orders :),all people are waiting to do .
until then i will support forum paying for 10 pc lot in advance.
Hi Kaushik,
this would be really nice to have some good finish cabs @ reasonable prices.BTW: first pic is from this site:
The DIY Chronicles, Part Four | Stereophile.com
Sachin
I hope the following is not OT , as wee are hunting desi diy parts .
may be the cabbie people are fraud, please contact/check any one ?
Possible low cost aluminum cabiie build:
i have got cnc people , but they are lil far 25km have water jet cutting,lasers or so taking front and back panels of 10+10 numbers may be possible .
1)i need autocad design files for standard sizes amp cabinet ..too lazy to do that !
2)aluminum pieces from sproad ..too lazy if someone can join inthis
3)clearcoat spray,for brush finish coating, i will import
or any one who can do this with normal saws:
as in the thread
I am also interested in enclosures. A default enclosure design with a potentiometer and iec socket will be a good starting point. 20 wide by 30 cm deep 2U and 3U height may be the default dimensions. Front aluminium plate at least 5 mm.
