HD Home Cinema from cinema
Cdodge
Chennai
Hi there,
I'm off to Singapore next week to buy a home cinema system, I think Im going for the following but any suggestions on the speakers gratefully received:
Optoma HD20 projector
Denon 1910 Amp
then for 5.1 speakers either...
Q Acoustics 1010i (2000 series not yet available)
Wharfdale 9.1 series
Jamo S406?
Jamo A102HCS5
As you can see I'm on quite a tight budget (approx 130,000 rps). Does anyone know approx current prices in Singapore for the speakers at the moment?
Chris
Is it better to get the Jamo 606 without a subwoofer than the Jamo 406 with a subwoofer?
Reliance in Chennai are doing the the S406 with sub for 32,000Rps or the S606 without a subwoofer for 38,000Rps.
Does anyone know if Jamo are any good?
Please check availability of the HD20. Before I got mine from US, I got my friend to check and the dealers there hadn't heard of Optoma.
