HD26 projector
Acceptable?:)
You would be better off sourcing from amazon through friends - about 600$.
For me 36k INR is acceptable, but none sells in India at this price!
I inquired with some projector dealers here in bangalore, and they quoted me 86k with 1 year warranty (3months on lamp) :), while same can be get in gray market around 54-58k, but they are opened boxes and not recommended at all
If you are not worried about warranty, amazon is best.
you can yourself add the product in cart and see the price that comes in the final cart, that would be easier. Also put it under wish list to see for any price drop
Looks like the shipping cost would be like this (Borderlinx)
Shipping cost * INR 3533.24 USD 53.25
Tax & Duty INR 7481.64 USD 112.84
Shipt protection INR 696.15 USD 10.50
Total cost to pay INR 11711.04 USD 176.59
Add to it 600 USD or 42k INR so total around 53k shipped to home.
Since import duty is is 29.41%, the tax component is more likely to be 12k and above (they usually lump shipping and equipment cost together and then charge import duty).
Anyhow, there maybe another 5k more costs. Still at 58k, it is 30k cheaper than India but without warranty. That's the risk one has to work with. Many a time there may not be a problem at all but if you are one of the unlucky folks, you may end up with a lemon.
Add another 3.5% (of total cost) as the international transaction / conversion charges if you are using a Indian Credit card.
in my experience, ICICI has been worst and standard charted is best as per the conversion rate :)
my 2c....
I too am planning to buy HD26 ,the price what i got is 68k in Bangalore
Is it a good price
which is a good screen manual pull down which will compliment the projector my budget is 10 k for the screen and where can I buy it in Bangalore
Hi Nikhil,
What would be the final cost of HD26? Can you tell me the name of the store and phone number and also warranty details. Appreciate your reply
ramesh
Is it a good price
The lowest i got for HD26 was 90k, i am shocked to hear that you got it at 68k.
I would really like to know the dealer contacts for this price. Thanks for assistance.
Not sure about the site, but the price is not at all attractive for a known refurbished product. You can get one from amazon.de for the same price, or check Bangalore/Hyderabad classified portals ...
pls inbox me i will share the number with you
i got a price of 12k +tax for 110 16:9 ratio Pull Down Screen Liberty is it a good price and will it do justice for my projector optima hd 26
Hi, What is the maximum screen size that we can go with HD26 without loosing the clarity of the picture... I was told that 120" is good but wanted to know if we can go upto 133" or 135" screen. Please suggest.
I could connect a 133 inch screen without any issues but my viewing distance is 20 feet from the screen.
Amazon has HD26 selling at 77K now.
