HDMI to HDMI And Optical Converter
shrayv
Chennai
Hey,
I'm getting a raspberry pi in a couple of weeks and looking to hook it to the tv as a media center. I am looking for a converter that splits the audio from the HDMI to optical out
HDMI in > Optical Out
> Video out (HDMI)
Shray
Sent from my iPad using Tapatalk HD
Is it available in India?
It costs $240. That's very pricey. I'm looking for something around Rs. 2,000-3000.
There is a 4x1 HDMI switch available at Monoprice.com but the product has mixed reviews
http://www.monoprice.com/products/p...=10110&cs_id=1011002&p_id=5557&seq=1&format=2
Octava has a rock solid 1 in to 1 out HDMI to Optical Audio converter that will convert the HDMI audio to optical toslink output.
The HD11-ARC is a unique device which combines an ARC compatible HDMI Audio Processor with a User Programmable EDID Emulator.
The HD11-ARC allows fully user customized EDID to be 'loaded' into the unit via USB from a PC to allow you to 'force' your Source into the optimum Audio and Video Output format for your connected Display and AV Amp.
Thanks for your suggestion. But I'm looking for a solution that costs about rs. 2,000 to 3,000. I was reading up a few articles on other forums and was thinking of buying a creative sound blaster surround external USB card that offers optical out. But I don't know whether it has Linux support and whether DTS/DD pass through works.
The current situation is that XBMC Build for raspberry pi don't support USB sound cards as of now (have alpha support).
Looking for your valuable inputs.
EDIT: OpenELEC (a build of XBMC) supports a number of dacs for stereo, nothing for 5.1 or multi-channel pass-through
http://openelec.tv/forum/12-guides-...lec-bit-perfect-stereo-playback-and-dac-guide
