HELP: Appropriate TV Size
amey
Pune
Hi all,
I have joined this forum very recently. I have read quite a few threads and found them extremely useful.
I am planning to go for a LCD/Plasma TV but not yet decided the size of TV I should go for. My living room is 19' X 10' and the viewing distance is in the range of 10'-15'. So what size of TV should I go for: 32"-27"-42"?
Also, if 42" is adequate, I am planning to go for a plasma (I liked Panasonic PV8 and PV80D).
Can anybody suggest the best shop to buy LCD/Plasma in Pune? My budget is around 50K.
Thank you all in advance.
You all are doing a gr8 job!
You have more or less all the answers. Go with the PV8, best bang for buck and also in LCD 42"+ will be more than your budget especially Full HD. Coming to size, the bigger the better always.
Hi all,
