Help buying a 42" TV - LCD or Plasma?
avenger1976
All,
After the Due Diligence, I have realised that I would be needing a 42 (ideal) or a 46 inch TV and not the 50" I was planning for. This give me more breather space, as I can look for more features in my budget.
Here are the factors which I need to consider before making the decision:
* TV for living room
* There is a considerable amount of light in the room (which of course can be moderated by a drape or something)
* Viewing distance of about 8-14 feet
* USB movie input would be ideal
* Full HD tv us what I am looking for
* Will play XBox games on it (HDMI side input will be best)
* Will watch F1, Tennis, movies and news mostly
What would you all suggest for the above?
I checked the 42" Panasonic G10 (final price - 71K) and X10 (64K)
Also am looking at the LG and Sammy's (42LH70, 40B650/46B650)
My budget is about 60-65K. And I have about 2 more weeks to make my decision.
What would you suggest? I am thouroughly thoroughly confused now.
All inputs are welcome.
Thanks in advance...
Praveen.
Praveen
Please use the search option, as there are plenty of threads running on this same topic.
* TV for living room - There is a considerable amount of light in the room (which of course can be moderated by a drape or something)
- For living room which is having lot of light will recommend to go for LCD
- Viewing distance of over 8 feet u can go for 42" LCD
For more that 10 feet of viewing distance u should go for 46" or higher
As watching a small size full hd set on a higher viewing distance would be
similar to watching a hd ready set at the same distance.
- Only LG & samsung models are coming with usb input, lg comes with Bluetooth also
- Usually all the tvs have 2 to 3 ports at back and one in front side
Plaxing xbox, go for lcd only plasma is ruled out
