Help me choose among these a/v receivers
jain1980
chennai
I have finalized the following receivers with their prices for my setup which consists of Wharfedale Satellite 5.0 Speakers and a yet to be decided subwoofer. My listening would be 50% Movies and 50% Music.
One is a budget setup
Yamaha RX-V373 - 26K vs Pioneer - VSX-323K - 18K
or Slightly expensive option
Yamaha RX-V475 - 38K vs Pioneer - VSX-823K - 31K
or the cheapest option
Pioneer VSX 523 - 16K (without warranty discontinued model)
I don't want Airplay or Wifi but I do want Bluetooth functionality through any compatible bluetooth adapters.
I have finalized the following receivers for my setup which consists of Wharfedale Satellite 5.0 Speakers and a yet to be decided subwoofer. My listening would be 50% Movies and 50% Music.
if you are ready to risk then Pioneer 523 is better choice.... If you want warranty than Yamaha 373 is better of the models you listed above...
Just worried whether the V375 has enough juice to power floorstanders when I upgrade in the near future? Also is it powerful enough to drive 4 ohms speakers without any issues?
Which one should I choose between the V375 and V475? Price difference of almost 12K.
