Help Required for Building My Home Theater
[email protected]
Hisar, Haryana
Hello Frn's
I am very much new to this field & don't know anything about home theater field. But what i know is that i require a decent setup for movie+music. I like to lisn ghzal & sufi music. i can't complete the setup in one time so my initial budget is 30K for future ready avr & Front speakers.& alter will add the centre, sub & the srrounds. my room size is 12'x18' & will connect the avr with my pc. though my budget is not much higher:mad: but hope you will enlighten me.:)
thanks you all in advance
welcome to HFV buddy,
I think you can try searching on the threads on HTPC and you should find some info basis that you can start your research and offcourse you will have some questions / queries which the experts in the forum should be able to help you with.
Spiro has built HTPC recently he should also be able to help you i think :-)
if you listen mainly to music think of a stereo setup and not surround sound. you will get much better sound quality for the same budget
Buddy I also want to watch movies on it.
you can also watch movies. you wont get sound coming out of 5 different locations but they will come out of your front two speakers with better sq. though also having surround sound is good. you need to decide what is more important - having sound come out from different parts of the room or better sound quality coming out from the front. its a personal decision
