Help to buy 7.1 Home Theatre Speakers
patelsiddharthr
Pune
I Recently Purchased a Sony STR DN 1010 AV Receiver (~276 USD). I have PS3 Connected to it. Now looking for the right Speakers to create a complete 7.1 channel home theatre system. I am in US for another 1 month or So. Shall i purchase from here or get it from India. I am looking for something arround Rs. 30-40 K.:p
Regarding speakers, do check shipping costs.
Speaker packages are heavy, so if you bring them as part of luggage, extra baggage fees might be as high as $200.
Yeah you are correct, baggage charges may be high. So where can i get good quality speakers in Pune and which company shall i go for.
In a budget less than 1-2 lacs, a 7.1 is out of question unless you are buying an entry level HTiB from Onkyo.
I would suggest a good quality 5.1 setup (assuming that music isn't as important as movies are).
For 40k, you can get Q Acoustic HTiB. For about half of it you can get Polk RM6750 or Polk 705.
You can also get Mission MV-8 HTiB for about 26k.
With your budget you can go for:
Wharf 9.1 + Wharf 9.0 + Wharf center + entry level sub
If you are in the states, you can go for this combo off ebay Polk
Monitor 50 $180
Monitor 30 $120 approx
Center
PSW110 $100-150
Will set you back around 25-30k + customs + extra luggage charges, so will turn out to be over 40k, but still lower than what you would need to pay over here
Hi siddharth,how much did you pay for the receiver,any idea whether we can buy it in India?
How much is the Sony STR DN 2010 available for?
Any other Sony AV receiver you can think of in the same budget,i mean mid range...?
hi
I am also on the look out of an avr + 5.1 speaker
I happened to see the following offers for speakers.
1.MV series Floor Standers fronts ,5.1+ms-10sub(200w) (Rs 30k )
2.Monitor Audio M Series with sub -(Rs.50 k)
3.Wharfdale vardus 400 Floor standers fronts,5.1 -(Rs.47k)
4.Wharfdale obsidian floor standers fronts, (w/o sub)-(Rs.38k)
5.Profx Fusion 6 Floor standers,with sub - (Rs 32k)
Want to check with you guys that whether Mission mv series is good,the rate is too tempting...
Which one of the above u suggest to be paired with Denon 1611 or Yamaha 567.
My budget for the entire set up is 60k max.
pls advice.
Dijeesh.
There are many other brands too in your budget paradigm , psb , qacoustics and polk rti series.
