I've recently shifted into a new house and was hoping to setup a HTIB in my living room. the room size is about 10x16.
My budget is between 40-50K.
I auditioned a few systems and have finally locked onto
yamaha 463 or 363(~20K) and wharfedale 70+ moviestar(~27K) .
The only issue is that the wharfedale's don't fit into my decor. i also recently heard that KEF 1005's are really good and might fit into my budget. But i can't seem to locate any dealers for the same in mumbai.
Does anyone know of a dealer?
and how much will they cost?
Can someone recommend a better speaker setup for a similar pricepoint?
Is this a good combination? or will the denon 1909 be better. I don't need 7.1.
I'll be attaching a DVD player and my WD media player to it. I'm basically a movie buff.
Any help will be appreciated.
