Help with LED Projector
bhuvesh89
delhi
hey guys..i will be buying a LED projector which my cousin will bring from US bcoz of my usage of aroung 40hrs a weeks as i will be watching football matches n TV series...
room size is small 11X11, the screen size will be around 85" bt these projector are fixed throw there is no option of zoom out as i want the throw distance to be about 10ft.
Projector will be ceiling mounted screen size dat is cuming is around 100" and i cannot mount at 8ft or so bcoz of my ceiling fan is cuming in between can u plz suggest me wid some option or any other LED projector.or can i throw from some angle to the wall..i m a total noob at dis.it will b my 1st projector.ny help will be great
You should look at some 'Short Throw' projectors, do a search on google or Amazon, you will know what I am talking about.
bro thnx for d suggestion bt i dont think dey come in LED and nyways i want d projector to be at the end of the other side so i can hook wid ps3,dth easily:sad:
