HiMedia 600 Firmaware updated 5 May
Cherian
Goa
An update after a long time,
Version 1.0.7.11, release date 03/05/12
>>Modified based on 1.0.6.17
New features:
1) Add multi-server support for HiTV
2) Network shortcut and local file (File browser-menu - Add to Favorites, NFS and UPNP isn't work on this function)
3) Support manually load the subtitle file. (Movies, according to the menu - the preferred subtitle, the player will automatically display the subtitle file in the same directory)
4) support f4v file format.
Bug Fix
1) fix the randomly failure on file copy.
2) improve the Network Diagnostics function
3) fix the issue about idx + sub subtitles
4) Fix the MP4 online seemless playback
5) Save the output change by "TV Mode" RC key
6) improve the PPPOE function
7) Fix the media db scan issue.
