home audio setup..budget 25-50k ok 75k.pls help!!
simply_amit
mumbai
hi this is amit.i am planning to buy audio setup for my bedroom.
bedroom size-15*22feet
music taste-loves bass..always listen to hip hop,pop,trance.hates treable!
do nt require VCD/DVD or even CD.
USB and FM is must.
would love if it has on/off timer.
i can import stuff from US.
pls help me guys...its really damn confusing and its not easy to audition many brands.
thanx
amit.
USB and FM is must.
thanx
amit.
Quote your budget, it will help people to advise. So are you going to play via a media player/ ipod dock/htpc?
thanx for your compliments for my room size guys..but i need some regarding my setup!!!lolz.yes i can stretch upto 1 lac max.am still confused shud i go for 2.1 or 5.1!
USB and FM is must.
thanx
amit.
If you can import from US, try Dr HSU VT 12 with a HSU sub for a suitable budget.
Hmm ok .How about -
Epos Epic 2 (till 48 Hz)
Monitor Audio RX2 (does 40Hz)
Dali Ikon 2 (till 41 Hz) .. though Dalis are not famous for their lower ends
Paradigm Mini Monitor (till 42 Hz)
For source, probably go with logitech Squeezebox touch or duet, which will give usb/internet and fm radio. Buy this from the US.
For speakers I think you should spend some money on a sub if you like a bass. Unfortunately good quality subs come expensive - in the range of 40-50k. But it may be a good idea to audition a few subs at various price ranges and see what works for you.
For example, check out the Wharfedales (9.1 +SW150) at the 25-30k range.
A similar combo with Polk and keep moving up the range of speakers and see what works for you. Check out Paradigm mini monitor/ MA Bronze also in the next bracket.
For a stand alone sub you could check the range from SVS, but it could push your total costs to probably a lakh.
For all-in one systems you could go for Boston acoustics/squeezebox boom/B&W zeppelin air. They are at the lower end of your budget, but its always good to check out using your ears than spend more and regret.
my basic confusion is shud i go for 2.1 or 5.1?
till now i had these in mind
option 1-NAD c316BEE+PSB alpha B1s+wharfedale sw150 sub(22+15+18)
option 2-audioengine a5s+audioengine AS8(18+18)
option 3-used adam A7 active monitors(45)
source-mostly sqeezbox touch.
I suggest u to go with NAD C326BEE+PSB Image B6. Trust me I have this set-up and it has a very gud bass which is more than enough for music purpose.
