Home Theatre Setup in 5 Lakhs
Kallushashi
Hyderabad
Hi All,
I need to setup home theatre for my new home coming to room size i am trying to build a new room for dediacted home theatre and Bar :) Please suggest me the best size for 7.1.2 atmos setup and also will i get all the setup with in 5 lakhs including good speakers for 100% movies,Projector,AVR,Acquostics,Reclainers and lighting.
PLease suggest me i am fro hyderabad
Hmmm ...
Guys from Hyderabad are gung-ho on dedicated HTs.
Kallushashi,
Reach out to FMs "samcruise" and "Aquarian09". They are from your town. One is in the process of HT building and the other has completed it.
Raghu
Thanks for the reply will i be able to complete the setup in 5 lakhs and i also need suggestion on room size how much will be ok for 7.1.2 atmos system can you please suggest the size also
6 recliners (good quality ones) will cost you 2-2.5 lakhs in itself. 3 lakhs for the system is too low to get an acceptable sound.
What is the size of your room?
What size of screen? TV or Projector?? This can be a start for recommending the room size.
Edit : Suggest ceiling height = 8 feet, width = 12.8 feet and length = 20.8 feet with 100 feet screen and two rows of seating.
It's a mistake to spend 2 lakhs on seating on a 5 lakh HT. If iam having such a budget I will allot like below.
Speakers and amp: 1.75 lakhs
Projector and screen: 1.5 lakhs
Acoustics and lighting : 75000
Seating: 75000
Cables and remote etc.: 25000
