How many watts can a 13 amp line handle
Yelamanchili manohar
Hyderabad
Hi all 😊..
I live in one of the modern crop of crap apartments with precast concrete walls with concealed in wall wiring. So if any wire burns, then it will be a outright nightmare to renew it, and will include ripping the false ceiling off.
My small room originally came with a 10 amp breaker at the mains. And when I had a class A amp with 380 Watts of continuous power draw, sometimes it used to trip the room's breaker upon switching on. Subsequently, I got the breaker replaced with a 13 amp one, and the tripping stopped. At that time, I had asked the electrician to replace with a 20 amp breaker. But we were not sure if the noodle sized in wall wiring could handle it. So I expect, that iam stuck with a 13 amp line for now.
Considering the above limitation, how many watts of electrical load can I put in my room without hopefully burning the wiring. Thanks
Hi all 😊..
Assuming that wire is 10awg or thick, 13x220 = 2860W
Wow.. Thanks a ton for your prompt reply @bornfi 😍🙏🙏
P. S : is there someway to verify if the wiring is actually 10 awg please.
Check the diameter of the bare exposed wire. Is it around 2.5mm. You can take a small ruler and measure the dia.
Here is a conversion chart
Thanks sir 😍🙏🙏.. Will do so. I was Infact expecting a reply from your goodselves.
I forgot to add that a malfunctioning MCB can trip for no *reason. That does not mean that your amplifier is sucking power more than your apartment can afford. What amplifier is it or was, if I may know?
*Actually, the items with transformers have something called in-rush current that is way more than what your amp is rated for. When MCB gets old/becomes faulty, it fails to handle in-rush current and trips. There could be other reasons too but this is something I have experienced. Changing MCB solved the issue.
You can get something like this and measure the actual wattage after the whole system is set up. https://www.amazon.in/Meco-Metering...d=1683120352&sprefix=wattmeter,aps,204&sr=8-5
