How to buy budget speaker stands for Wharfedale diamond 12.1
kvandhi
Chennai
I am planning to upgrade Wharfedale diamond 12.1 speakers. My current setup is using laptop as source and mainly nearfield listening. Which speaker stand will accommodate WD 12.1.
Please share your suggestions on how to select speaker stands. This is first time i am buying, so far used it on my table only. There is lot of confusion on it should match ear level - tweeter height. How to finalize all these for near field listening.
check amazon, there are a few over there.
i got one of those for my rear speakers
you can always get a carpenter to make you one. urban company has carpenters service, check it out
with adjustable stands its easy to get the right height for your tweeters
with a custom made wooden stand, you will have to make it with right height. pretty easy with any carpenter.
Check soundfoundations web for speaker stands
