HT / stereo setup for under 1 Lac
mehtah
mumbai
Hi folks,
I've been reading the forums here for past few days and its fantastic to see a vibrant community of audio/video enthusiasts out here.
I am renovating my living room (~ 10 ft wide x 16 ft deep) and am looking for ideas on receivers, speakers, cdp setup for under 100k. I will most likely split my listening time on HT/DVD vs. stereo to 50:50
One basic doubt I have is if a 5.1 or 7.1 receiver be good enough for stereo?
thanks for your help.
As per your budget the following would fit into your budget:
AVR: Denon 1610 for around 27K or Denon 1910 for around 37K
For Speakers Package: Wharfedale DM 10.1 BS with Stands around 17K
Center Wharfedale Dm 10 CC around 10K
Wharfedale DM 10 DFS around 10K
Polk Audio PSW 125 sub around 15K
Wires : around 5K
Another 10K you can spend on a budget DVD player from the likes of Cambridge audio model no. DV99 or If you wana go separate route like a Separate CD player then you could find one from Marantz / Cambridge Audio stable and a DVD player from the Pioneer stable.
Depends on your taste and/or budget, if music is your preference go for a stereo setup (amp + 2.0) first. You can then get a AVR with pre-outs and the rest 3.1 speakers and integragte both of them.
Hey Buddy
Please find the details below :
5.1 Package
1). Q Acoustics - 1020i + 1010i + 1000ci + 1000si with Denon-1610
with Spkr Cables and HDMI Cables with Speaker Mounts and
with Pioneer DV-410 = Rs.1,02,500 MRP
After discounts you can exchange Cambridge 340C CDP,
instead Pioneer DVD Player.
2). Q.A.V. - Q.A.V. 5.1 Package with BMR Drivers with Denon-1610
with Spkr Cables and HDMI Cables and
with Pioneer DV-410 = Rs.1,10,500 MRP
After discounts you can get the same for almost Rs.1L.
7.1 Package
3). Q Acoustics - 1010i x 3 pairs + 1000ci + 1000si with Yamaha-663/665
with Pioneer DV-410 = Rs.1,14,500 MRP
After discounts you can get the same for almost Rs.1.05L.
Stereo Package
3). Q-T.V.-2 - 2.1 System works as a Jacket to your TV, is attached to
your TV output, Sounds Seriously Amazing = Rs.35K
Appropriate for 12 x 10 Bedroom.
4). Q Acoustics- 1050i + 1000si + NAD CD Player + NAD Stereo Amplifier +
Speaker Cables + Optical Cable = Rs.1,16,000 MRP
After Discounts you can get the same for almost Rs.1.05L.
