HTPC upgrade suggestions
piyush608
new delhi
Please help me upgrade my HTPC
current config
MOBO:Gigabyte GA-B75M-D3H
Processor:inter core i3 2100(something)
Ram: dynet 4GB DDr3
GPU;MSI Nvidia Geforce N210
HDD;1TB segate
Want to upgrade:
HDD to SSD
PC cabinet to horizontal profile as current tower profile doesnt fit into space.
Graphics card if needed
PC will be used for :Mainly Movies (HD 5-8 GB DLoaded) and moderate gaming(for eg First person shooting COD MW2)
also suggest good wireless keyboard mouse for the same.
If it is mostly for movies, then an Android TV box for 3 - 4K on amazon.in will do.. It can play most movie codec and support bit-stream to AVR (All HD codec)..
However since you are also looking for gaming, then upgrading your GPU might help.. Am not a gamer, but have read that GPU with 1GB DDR5 spec is good and better..
I have been using Logitech wireless keyboard & mouse for a long time, just works fine.. Has media control buttons too.. (Don't recollect the model #)..
Can Android TV box output 1080p and bitstream Dts trueHD to AVR without any lag? I was thinking of buying used laptop for this purpose. Which Android box around 6k?
Yes.. Any Android TV Box can output 1080p as well as bit-stream Atmos/ Dts X to AVR.. I have used both Generic chinese ones as well as Xiaomi Mi 3 ATB.. Both were just fine..
Since you can go up to 6K, then Xiaomi Mi 3 ATB, the only affordable ATB with Android OS for TV.. As far as i have tested, it works with 1.5 TB external HD..
@elangoas is right.
An Android TV Box like a MiBox 3 will be far simpler to set up and use than any HTPC. My Mi Box 3 works with a 4TB drive too, I have mine connected over the lan to play 1080p content to a projector. The Mi Box works great for 1080p not 4K though.
