HTS3571 - No Sound
sun244
Friends,
After working for 5 years, the unit is malfunctioning. Just curious whether any of you faced the same issues as follows since many of us bought this unit at the same time. :clapping:
The issue is, there is no sound coming from any of the speaker. I can play the DVD and get the sound from TV speakers. For last 2-3 months, it used to give sound after 5-10 minutes. Following are the things, I have tried:
1) Upgraded the firmware, no luck.
2) Opened the box and pressed all connectors
3) Removed all speaker connections and plugged it back.
None of the above, helped.
Do you guys have any suggestions?
Also, any repair shop you suggest?
I suspect all speakers and woofer should be in good condition since I cannot believe all of them can fail at the same time.
Can you please suggest home theater system I can buy that can be connected to the Philips speakers and woofer that came with HTS3571?
Thank You
Sun
Friends,
Looks like none of you may have experienced this type of issue :-)
Can you folks please get back on only following?
1. Any repair shop in Basavangudi / Jayanagar shop?
2. Provided HTS3571 speakers and woofer is good, can you please recommend only the player that I can hook up old speakers/woofer?
Thanks a lot for all the inputs.
Sun
