chaitanyaht3
Dear All,
With my little understanding, I picked 5 models for android TV box.
And can you suggest a better one please?
If any one is already using one of these, it will be a great help with your feedback.
MY REQUIREMENT:
Must bitstream audio form Netflix and Prime.
Play Lossless audio formats like TRUE HD and DTS-HDMA etc (if bitstream works, this doesn't matter i guess)
Play blueray movies from hard disc (4k is not required)
MY PICKS: (see the attached image please)
1. Tanix TX3 Mini (3.5k )
2. X96Mini (3.5k)
3. MXQ pro (3.2k)
4. Mecool M8S Pro (6.5k)
5. T96 PRO (7k)
First 3 models are under 3 to 4k price range, and the last two are around 7k.
(Not sure why they are more, may be good hardware? )
I do not use gaming at all.
Can you help with my choice please ...
Thanks & Regards
Chaitanya
MY REQUIREMENT:
2. X96Mini (3.5k)
3. MXQ pro (3.2k)
5. T96 PRO (7k)
Thanks & Regards
Chaitanya
