In Ear Headphone Around 4000rs.?
My friend recently bought Sennheiser CX 3.00 from Amazon, it has excellent sound quality for money and very good separation. You will not be disappointed buying these
Any one own SHURE SE215.?
I am really considering this as i have seen so many good reviews about it.if anyone here can help me out .
What kind of sound signature you are looking for?
First of all, you need to make sure the sound signature you are looking for and then search for the IEM as per your required sound signature?
There is nothing called best in the market.......but there are definitely better.....
General opinion in the forums is that SE215 sound quality is not great. However, there are people who are happy with it. Build quality is supposed to be good. SE215 normally retails around $100, not really a sub 4k IEM.
Check out
* FIIO EX1
* Ostry KC06A
* Havi B3Pro1
* Vsonic VSDS5
* Trinity Techne
i extended my budget because some iem caught my eyes . i read so many good reviews about them.i am confused between shure se215 and sennheiser momentum in ear. so anyone here help me out to decide between them.
thanks.
Check out
* FIIO EX1
* Ostry KC06A
* Havi B3Pro1
* Vsonic VSDS5
* Trinity Techne
chinese IEMs are a gift from god
FiiO EX1 or Hifiman RE400 Waterline. Both are under 7k. The latter is under 5k.
Either should be head and shoulders above anything from Sennheiser under 5-6k.
I am using hifiman it is pure mid clarity like BBC monitor speakers Ls3/5a series. But poorly built up. Bass quality very lite. If u raise the volume while playing poor recorded songs it will behave badly. Other wise with hi resolution songs and 320 kps songs it is flawless dead netural with bass lean.
