[India] Need best 2.1 speakers withing INR 5-6k
rachitsaran1987
Gurgaon, India
I am looking for the best 2.1 speakers withing the range of INR 5,000 to max. 6,000.
The options I am looking at:
Sony SRS-D9 (have read they are good all-purpose speakers)
Edifier C2XD (although, haven't been able to find it anywhere online)
Altec Lansing MX 5021 (again, unable to find it online)
I will be using the on-board sound card. My usage is generally movies and music, but I am looking for as close to audiophile experience as possible for songs!
U won't b able to find Edifier C2XD & Altec Lansing online. I tried the same thing & couldn't get anything. I saw C2XD in Itdepot & even ordered it. But got call from them that they were out of stock. Then I went for Swan M10
If u can raise ur budget to 9000 then Swan M10 can be a better choice. Otherwise u can check Edifier C2 (4000-4600 INR) & Edifier HCS2330 C2-PLUS (4700 INR). Both r in ur budget & available on Amazon.
Thanks for the reply!
But if Edifier C2XD is significantly better than C2 or C2 Plus, shouldn't I go for the C2XD?
Do you know any shops in Delhi NCR where I can go and buy it then?
In case, Edifier is not present in any shop, what are your views on any other ones that will be available online?
Welcome Rachit
If C2XD was available then surely u would go for it. But its not available in any online sites. Check local shops, if u'r lucky then u will get it. I'm not from Delhi hence can't tell u any specific shop.
I m still suggesting that if u can raise ur budget to 9000rs then u must go for Swan M10 otherwise C2 or C2 plus r already in ur budget.
Thanks!
Anyone else have any idea? I really do want to get Edifier C2XD. Swan M10 is out of my range.
Have contacted Edifier on their facebook page as well as through their enquiry email id on their website. Will update.
Thanks!
You will get in in Nehru Place. I had seen it when i was looking for it around 8 months ago. Most of the models of Edifier were available in those shops.
