Is it possible to get 3-way LCR speakers under 1 lakh? all the three L-C-R
Yes it is possible to get "decent" LCR in 1L odd. There are many brands out there that you can consider.
Look at Elac, Wharfedale & Q Acoustics to name a few - beyond that look for combinations to suit your budget.
For example -
QA concept 20 + Concept center is under 70K
Elac Debut 6.2 + 6.2 center is also under 70K
Fyne audio, monitor audio, wharfedale, offer a few options under that price.
In under a Lakh with some combinations you can even accommodate Floor Standers instead of Book Shelves.
For just over 1L (maybe under if spoken directly to the dealer for discounts) you can even have ELAC DBR 62 with the matching center.
Here you go! Happy shopping.
Taga Harmony has a few models
Platinum LCR-60 SL
TAV OW-60
These would be around 20,000 each
AZURE OW-80
This would be around 30-35,000 each
Platinum LCR-60 SL
TAV OW-60
AZURE OW-80
Azure OW-80 ... specs are good... what about the quality ?
If u r a fan of On wall then u can get Jamo D500 LCR,am using them and they r brilliant
I don't know but it's a 4 ohm speaker. People get worried to go from even 8 to 6 ohm... is it advisable to go with 4 ohms ?
Most manufacturers play with impedance ratings - the impedance of every speaker varies with frequency and usually goes down to 4 ohms at some frequency. Most AVRs these days come capable of driving 4 ohm loads or higher current. Which AVR are you using?
Yes..slightly above or 1lakh
Concept 40s -80k
Concept center 26k but should be negotiable
Is there any difference between Concept centre and 3090C ? Can we use Concept center with 3050 towers ?
Am using Denonx3600,never clipped. I always keep the setting at 8ohms in AVR and Eco mode Off.even at -5db it never shut down.
I have Denon X2700H. What is clipping brother ? And what is -5dB and not shut off ? Sorry I haven't opened my AVR yet... could you please explain?
Denon X2700H
I am using Concept 20 + Concept center with X2700H, absolutely no issues, the AVR is yet to run out of power.
Most 8 ohm speakers are actually 4 ohm speakers.
This is because most 8 ohm speakers dip down to 4 ohms or less.
The relevant international standard specified by the International Electrotechnical Commission (the IEC) specifies that speakers rated at any impedance must not fall below 80% of their nominally rated value.
With that abovesaid information, look at the minimum rated impedance of the loudspeakers you're contemplating and you'll realise that more often than not, they dip down well below the 80% minimum mark.
So then, the speakers which are nominally rated at 4ohms are simply being honest about their impedance whereas those rated at 8ohms are... Well...
The only Speakers below 1L that I'm aware of which do not dip down below their 80% rated value are the Dynaudio Excite X14s.
As far as the rest are concerned, they are all 4 ohm speakers in my opinion.
In the interest of greater awareness, I request other FMs to chip in on this issue as i believe this is a topic less touched upon but one that often leads to many misconceptions.
I'd recommend sticking to the 3090ci as it's tonality is consistent with the 3050i towers.
The concept center sounds quite different to the 3050i and will lead to an inconsistent surround sound experience i.e. when the sound travels from the center to the L/R channels, it'll sound different and detract from the immersion.
Got QA 3000 series HTib setup(3050, 3090c, 3020)! Connected only towers for now. Need Suggestion for a Sub. i would like to have a decent sub not earth shattering one. I recently experienced one of the SUBs from Klipsh. it's a 10 inch 200 watt rms class-D amp costing around 65-70k i guess. at 25% of the gain it was shaking the entire room.. Don't want this kind of one. need a softer sub.. any suggestions please!
For a softer, musical sub - do check out Q acoustics QB12, it has reduced a lot in price recently and I saw it somewhere for around 40K odd. Not saying it is the best out there, but it is a pretty easy sub to integrate in our less than ideal rooms :)
