Is there a way to reduce impedance of speakers?
anm
New Delhi, India
Maybe this thread belongs to speakers than amps. But I think it equally belongs here too.
Suppose my amp is rated for 4 or even 2 ohms, and power doubles if I half the impedance. Now to feed more powers to the speakers, is there a way to reduce the impedance seen by amp, so it pumps in more power into the speakers?
Has anyone tried this?
regards
regards
Yes, there are ways to do this, but this will not help you as with a lower impedance of the load, the amp is putting out more current/power for the same efficiency. So in effect you are driving the amp harder to get the same overall loudness.
cheers
theoretically, the best solution is to put a load matching transformer in between, but transformers working across the audio frequency tend to be a bit expensive - tend to be found on valve amps and electrostatic speakers
the power delivery of the amp will not become 2x- thats the theory anyway. You will end up drawing more current , and will cause the amp to distort even more!
