Would you go with the passive instead of the active? If yes, would the nad c368 with MDC bluos be sufficient?Are you buying them new?
The most obvious thing that they don't tell you is that the in built dac is not that great.
The soundstage is amazing but I didn't find the level of detail/resolution to be that great.
Would you go with the passive instead of the active? If yes, would the nad c368 with MDC bluos be sufficient?Ive owned them.
They are great speakers. Heavy stands are a must, if you place them on a desk, make sure the desk is heavy and try to get something like the ISOAcoustics isolation stands.
After from that, id probably look for a separate DAC or a music streamer with built in DAC., if you want to fully take advantage of what the LS50W is capable of doing.
The DAC is the weak-link in an otherwise fantastic package.
No I don’t like the passives that much. The amplifier pairing in the actives is much better.Would you go with the passive instead of the active? If yes, would the nad c368 with MDC bluos be sufficient?
Thanks. Can I directly attach an external hard disc via usb to the speakers? Or only a computer can be attached?
