I never said they were small. You want bass, you’ll need big speakers. You can’t cheat physics![]()
Keep it simple newlash09. Why would you want to do passive tri amp? One simple Parasound integrated with the Tekton should do the job nicely. If you want to tri amp then go get PMC or ATC actives and be done with
@newlash09 For the phenomenal potential of the Alpine, you should go fully 4-way active.
Iam off to the tektons.
Hi Did you eventually buy the Tekton DI.Hi prem
I did consider selling everything and going with actibe atc scm 40's. But after having heard a few systems around. Felt the possibility to tune the sound will be very limited. So decided to add tubes for mid range and treble and SS for bass. It is more of an experiment. And Iam not even sure I posses the necessary knowledge to even see it through. I will be removing the passive crossovers completely .And all drivers will be directly driven by my power amps.. And since my problem is with the recessed mid range of the pmc, I will run peq in roon, to bump it up to compensate for the design. So interesting times ahead I must say. Iam not sure if it will be a positive result in the end. But having invested in this project...I'd like to see it through, even if it fails for my own learning
I had the Pendragons for 3 years and sold it recently. I also have the M Lore from Tekton Design. One thing I found in back to back unfair comparison (David vs Goliath) is the M lore's are more detailed in highs and mids. They will need a sub however to match the bass missing as compared with the Pendragons . However in Pendragons the detail sometimes gets missing as the Bass /low end reproduction kind off subdues/over shadows the details. Thats not good actually .
Also one thing to note in fact is the Tweeter array produce the mids . The 10 inch woofers are eminence PA drivers and do the low end.
I have just ordered the Tekton Lore @ $1000 to solve the issue of detail . Lets see.
Thanks,
Thanks for the update . Its quite nice to actually do a DIY project. Best of luck indeedHi naj
Thanks for sharing the above. I ultimately didn't spring for the tekton speakers. And instead embarked on a DIY speaker project , with a very kind , benevolent and knowledgeable forum member. Iam really excited with this project
( And may be I should add, that iam very grateful to prem for showing me this unknown possibility till then )
And another thing that transpired in the interim is the addition of some tube amps to my present PMC speakers. Finally got them sounding lovely.
Next step will be to go for biamping. I already have the necessary kit at hand. But just too lazy to give it a try so far.
