laminate screens
Hi Piyush,
You could try Greenlam grey coloured sheets which are available in sizes 3X7, 4.25X10 5X12, 5X6, 6X12 (all Feet); thickness varies from 1 to 1.5mm and upwards.
My friend has used (1) No.929, Metaline Grey and (2) No.270, Sliver Grey (both non-shiny matte surface).
images on these are 'acceptable' and 'enjoyable'. I have had no opportunity to compare them with international brand screens, but these laminates do certainly hold up against any ordinary (5-10K) screens. I am planning to use one of these. When you are immersed in a movie, you hardly notice any difference. Laminates do not have wrinkles, are long lasting, washable, and are easily maintained and cost effective.
have your laminate suitably mounted; large sheets require centre support.
Greenlam has a huge sample collection which your local carpenter or greenlam seller will gladly show you.
Good luck and get back on the forum to share your experience.
Can some one help me in buying projector pulldown screen 110inches 16.9 format or 120inches 4.3 format. Where cani buy in less price , madras or bangalore. Also I need 15m hdmi 1.4v cable. I checked deltapage website. Also I need to buy power cable for 15m for projector power adapter which is circular female 3 pin. Also 3feet ceiling or wall mount.
