LCD As A Source For a Stereo Setup
Saket Upadhyay
N Delhi
i hve a samy lcd which i want 2 use a source for 6002 matanz amp. with jamo s 718 speakers....... is there any technical issues with it???????
guidence needed from the guru's...
there wont be any technical issue however do not expect great sound.. you can take the output from the tv and connect it to your amp and then to your speakers.. however not sure what quality the lcd will be able to deliver..
also what lcd is it ??
it has an analog out or digital out ???
and if its for watching tv then you can connect stb directly to amp and video to tv ..
if its for movies then has to be taken from the tv..
please mention the tv model..
best option will be optical out and connect it to your avr...
else stereo sound can be achieved with the headphone out from the tv..
just get a RCA cable and from tv headphone out connect to avr.. stereo in..
if stereo is is not there.. then get a rca cable with one head of rca 3.5 mm for headphone out and other end splitted to (red and white) right and left sound and connect to avr for any input say audio 1 or 2 or 3 and on avr select the input and you are good..
else optical out from tv to avr.. best..
