Led panel edge
Birendra
navi mumbai
Does all the LED panels edge or corners ....if pressed goes a bit inside or stays firm. ....? because when i press my LED TV's edges or corners of the panel it is going a bit inside...?
can someone confirm...?
^ Stop pressing the TV to avoid any damages and only watch it. Btw, not all panels are same made the same way. Some panels are soft, some panels are hard based on the protective panels if available
