viren bakhshi
Lyrita Audio introduces horn speakers to compliment its range of tube amplifiers. These high sensitivity speakers combine well with any of Lyritas tube amplifiers, to reproduce the rich tone, texture, and scale of music.
These are two way systems, using professional drivers, to take advantage of their high sensitivity and power handling. Horn loading improves this further, and also gives a heightened sense of dynamics and scale. Of course, the tube amps, with their low power output, do not stress these drivers at all so, there's no compression in the sound even at high levels.
The compression driver, which reproduces the midrange and high frequencies, is used with a custom designed solid teak wood horn, using the special LeCleach horn profile. This combination gives clarity to sound which is exemplary.
Lyrita Horn Petite
Two way, part front horn loaded speaker system
Sensitivity...............96 dB / watt
Frequency range.......50 Hz to 18 kHz
Impedance...............10 ohms (100 Hz to 20 kHz)
Driver mid/high.......Eminence PSD2002 with LeCleach wood horn (600 Hz cutoff)
Driver bass............Eminence Beta 12A-2 (12) in closed box enclosure
Crossover................800 Hz, first order Butterworth
Price, per pair...........Rs.95,000
Lyrita Horn Grande
Two way, full front horn loaded speaker system
Sensitivity...............100 dB/watt
Driver mid/high........Eminence PSD2002 with LeCleach wood horn (600 Hz cutoff)
Driver bass.............Eminence Gamma 15A-2 (15) in front horn enclosure
Crossover.................800 Hz, first order Butterworth
Price, per pair............Rs.145,000
Viren
Lyrita Horn Petite
Lyrita Horn Grande
Viren
