Mark Audio A10p
badrisuper
chennai
Planning to start a speaker build using MA 10p. I am leaning towrds Brines M10A10. Has anyone tried MA10p?
I got a nice 8 inch full range driver from a friend. It looks nice and sounds good. Driver specifications are unknown. Has anyone seen these drivers before?
Badri M
i have tried Brines M10A10 for alpair a10 model (few years back). it played well. although nothing special. the bass is difficult to control in this box. for some reason alpairs sounded better in bookshelf although with lesser bass.
Thanks Soundnovice. which bookshelf cab do you suggest?
whats ur room size and source setup?
your tried paper version or metal one?
Badri M
there is slotted compact bookshelf design. you will get it if you google. when i built it, my living room was around 12 by 18 or so. source was an oppo cdp and i had couple of amps. norge and tripath.
