Mark's ER18 build- Inductors needed
crisscross
Hyderabad
I am building Mark's ER1818 speakers.The Seas ER18DXT ported two way
I am also building a ClassD Amp to drive them but that's for another thread.
I have all the parts I need except for the inductors.. do you guys know any suppliers you can recommend? I tried Corrson but they said they won't do small volumes..
I have Corrson bookshelf speakers' HF & LF 2nd order crossovers & crossover point is 2800 hz. Im going for active crossovers & dont need them.
There are quite a number of winders in Hyd. Why don't you get them wound as per your spec?
Arun, looks like a great design to build.
The guage of the wire required
is also mentioned, so that makes it a bit easier.
See if Mr Natesh of Hy Magnetics, ECIL X-Rds, can make them for you or
give you a lead to someone who can do it for you.
http://www.thomex.com/hy-magnetics/transformers-marine.html
Another one to try is Suresh Hebbar, Electro-Magnetic Devices in the same
area. They are into transformers, but should be able to do it.
