matching front tower spkrs for pioneer VSX AX4
lselvam
i just bought pioneer VSX ax4 av recvr
i want to know matching front tower speaker for this amp
my budget 50000 rs for front iam planning to add surounds later
iam upfrading from denon avr1705 with jamo satellites to pioneer av recvr+plasma and new spkr package
polk audios monitor 60 or jamo idon't know which model will suit this amp
please recomend ,any AX4 users please
hoping some friend reply :
regards,
l.selvam:)
Try to audition the PSB Image B55 with your receiver. If you are in Mumbai I believe Lakozy near Chowpatty stocks them (not sure). Polk's RTi range is far better than Monitor. Also look at Monitor Audio's RS and BR2 ranges.
hi,
you can also try quads (i forgot the model no, i will get it) they are priced at 36 and sounded awesome.
Vivek
