Measy Network & 1080p Full HD media player (E8HD)
Specs are same as playon hd , including the chipset version. Currently playon hd is sold for 7400/-. I'd prefer a known brand anytime than unknown chinese clone.
Just my 2 cents.
Yes Its true It has HD audio. May be due License problem they have not mentioned Dolby and DTS in the image and the spec
its got the old RTD1073 which is nt very good nd the kbioner one with k360I is better buy than this...has the latest chip and bit lesser than this..
sony bdp 380 is good choice for buying .player supports dts hd ma.i checked various movies of dts hd ma from seagate 500 gb .i bought from ebay for 6690rs
Thanks for the info. At this price of Measy X6, better buy would be AC Ryan PlayOn HD2. Only gripe is you will not get Wifi adapter.
Well for AC Ryan HD2 price, we can also get Kaiboer 360i built in wifi and 1tb internal hdd...Tax can be worked out on kaiboer :)
