Mitsubishi 110U Projector - Line Resolution.
deba
Kolkata
Dear All,
Kindly let me know what is the line resolution of the Mitsubishi 110U Projector , it says the native resolution is 1024 X 768 Pixels.What is the resolution in terms of line.
Kindly visit the following link:
Mitsubishi Projectors: Mitsubishi XD110U DLP projector
It says 1080i and 720P as compatibility. - what does it mean ? Will it display 1080i and 720p resolution.
Will it support 1080/720 if connected from y cb cr of a blu ray player to vga in of projector.
Kindly guide.
Dear All,
Kindly guide.
it says that it is compatible with max 1080i input, but the native resolution is 1024x768, which means that 1080p signal over component is not allowed.. u would have to change to 1080i/720p in the bd player..
after that the signal would be changed to 1024x768 native (4:3) aspect which means the black bars would appear in the 16:9 video from the BD player
so in short lots of loss of quality
