MM cartridge for Panasonic PL 400
Hi Srini, any Audio-Technica stylus with universal head should work.
Importing it from US is expensive. Audio-Technica MM stylus is available at Chennai.
MOHAN MUSIC
M.Sasikumar
#6, Ritchie Street, Mount Road, Chennai-2
Ph: 28415165
mobile : 9840496860
Thanks to N.Murali for the contact address.
Anil
Can any body suggest me suitable cartridge for the Panasoni PL 400 Turn Table?
Srini
Hello,
The model No is AT-91 pl quote while ordering.
Thanks to Anilkumar for making my job easier.
Thank you,
N Murali.
Anil and Murali,
Thank you very much for the info.
Just spoke to the person and he quoted 1250.
I brought the TT recently (rs 2500) and want to change the cartridge.
I am using Azur 640P phone pre amp to rip my LP/EP records.
The records are in good condition but still I see some rubbing noise like.
I hope changing the cartridge improves the quaity.
Please advice.
Srini
What is the effect of Toenarm adjustment on the quality of the output?
Inproper balance damage quality of the output?
I am getting good quality from one RCA output and the other one had some noise (like when no earthing).
I am confused the problem with the Per-amp I am using ? Or Toenarm adjustment? Or cartridge.?
I Appriciate if any one can come up with a soulutin
