More Turntable Options for Indian Audiophiles - Origin Live UK
Dear Members,
Goldfinch Acoustics is proud in launching Origin Live, UK Turntables in India. Origin Live offers excellent value for money, offering performance better than competition costing many times more. Origin Live is hand Crafted in the UK. we are proud to be associated with one of the best Turntable brands in the world.
While our website is getting updated to add the Turntables, here are some pictures for you. Feel free to call me at 9900059087 or drop an email [email protected]
Some Key Advantages of Origin live
Fit & Forget
  • Nothing to go out of tune so you save the cost of yearly servicing.
  • Simple to set up for beginners.
  • Proven reliability from time tested design.
  • Simple to run using a single switch.
  • Upgradable with Tonearm and motor drive options.
Easy Set up
The deck is simple to set up for beginners. The instructions are written assuming you’ve never had a turntable before. From the box arriving and after reading the instructions, set up takes between 5 and 15 minutes. This incudes fitting the arm (not the cartridge).
In contrast, many Suspended turntable designs can take well over 2 hours to assemble due to complex spring assemblies, levelling and other issues.
All our decks are easy to level with adjustable feet.
Arm fitting and VTA adjustment is convenient, with open access to the underside of the armboard.
Near Zero Maintenance, high reliability & low Running Costs
Nothing requires tuning thanks to non-suspended design which means you save the cost of yearly servicing.
Speed will not vary into the future (see Light Speed Controller LSC). In contrast, the speed of most turntables changes over time unless they are serviced by a dealer. Even then the accuracy may be no better than 0.5% not to mention inconvenience and cost.
Level of reliability is proven by time tested design.
Easy to Upgrade
Various turntable upgrades are available depending on the deck model. These can be seen as options on order pages or on the turntable upgrade pages
Upgrading the Tonearm is especially easy due to the simple fit.
Simple to Run
Our decks arer simple to run using a single switch.
