My Current Set Up - SR6006+ DX-1 and Strada yet to be paired
SatMumbai
BOM, BLR, DE
I just want to share with you my current set up. This is really a small set up but is very enjoyable! After many years of going through cable clutters, trying to untangle the various cable management systems, I found this latest implementation to be very easy with respect to setting up and maintenance.
I am sure many of our local carpenters can make these wooden boxes. I used a normal 18mm plywood with an ivory sun mica. Got enough holes drilled on the top as well as side to have a non messy look. The front frost glass helps to hide the equipment partially and the remote works with out any problem. The top holes help is natural heat management. If need be a fan can be installed inside. So since the vent holes are on top the hotter equipment (AVR or power amps) need to be on top and hence the partition inside the wooden box is made asymmetric. Top has more space and bottom is slightly less tall but most of the other gear (I mention them below) do not need so much space anyways.
Hope you like the design and if you do so and want to use it for your set up please feel free to use the design cues!
HT Set Up:
Sony 55EX725 | Marantz SR 6006 (In Silver Gold) | Wharfedale DX-1 (In White) | Tata Sky HD | Apple TV | Wired Power Cable Router | Blu Ray Player (Samsung?)
5.1 System is installed only in 3.1 Mode at the moment
Nice setup; simple and clean. I especially like the way your white coloured speakes and cabinet blend into the room's asthetics. Lighter colours are always better to make the room feel large and spacious.
You got that bang on! Given the very small apartment that we have right now, this is the best that I could fit in along with the people. And the colors became even more important to make it look not so overwhelming!
Nice to finally see someone into white :)
Thank you! I have been into black color before. When I had the B&W CM9 in Piano Gloss Black, i was very happy but it was only for the first two days. After that I understood what a big dust magnets the Piano Gloss Black was! Then I went for wood / natural brown / cherry / mahagony depending on the speakers but never white. I got the Kef R300 in white and they looked so airy (colorwise) and so decided to go for white speakers in Mumbai as well! I am glad it looks pretty good :)
Nice setup. Very well done.
Did you procure you Anthony Gallos in India? From where?
Thank You!
I have bought them when I was in Germany. But the good news is I did not buy from German Dealer but from a US eBay member. They were shipped brand new in box to me and if I remember it well I guess I paid around 1400 Euros for the pair including shipping & customs.
Pictures of Jolida JD1501BRC
The Amplifier
500VA Insulated Torroidal Transformer - Self Branded
Innards of the Amplifier
Pre and Power Amplifier Section (towards the right side of the amplifier)
Actual Power Amplifier Chips National Semiconductor LM3886 / Two Per Channel with massive Heat Sinks
Tubes (I guess in the pre-amplifier Section) though they are on the same board as the Power Amplifier. They have the same amplifier in Power Amplifier version. So is it possible that there is just a passive pre-amp section with volume control and rest everything is a power Amplifier Module?
Svetlana 12AX7 Tubes (Two in numbers - Only one is taken out to Photograph)
There is no tube glow even when the amplifier is ON.
Picture of the Real Panel with XLR input and Variable as well as Fixed Output (Currently using the variable output to drive the subwoofer)
Great set up Sat! How much did you pick the wharfedale dx1 for & any idea if 'the shop" still stocks them? thanks!!
@SatMumbai : Awesome looking setup, tempted to copy but will have to change my HT stand which is in wine red.
