keith_correa
You're going to solder SMD's :clapping:...Have anyone heard this DAC or has any other suggestions?...
...I am also smd expert by hobby...
....and I am super-excited about it.hyeah:
I am also smd expert by hobby, fire questions
irons ? flux ? Magni ? tweezers.. solder or any other questions
I suggest grab the Hot audio DAC and dont go for Grub dac DIY if not needed .
I have successfully soldered couple of amps. Its easy to solder and remove SMD parts except ICs. Only problems arises when you sneeze in front of them before soldering.They just vanish from table.
I have done a bit of beautification of my headphone amp by putting it in an enclosure from Hammonds.
Below are some eye candies
After the completion of my headphone amplifier, I am scouting for some good USB DAC kit which is simple to build and have some decent sound output (compared to the laptop's headphone out).
Wowie, that looks very pretty.
I'm wondering how you managed to get the holes for output jacks in perfect alignment. It almost looks like it was custom moulded with those holes.
Just wondering if you had considered the Pear Audio / Buffallo DAC kit, based on the recent ESS DAC. The DAC has very good specs on paper. One drawback, if i remember correctly, was the default kit didn't support USB.
Well, you have been very skillful with the knife. Very clean. Like I said, it almost looks custom moulded.The ABS plastic is pretty much soft and I easily made the holes using a craft knife.
He he. I know that feeling. I've myself been thinking of doing the CMoy from a long time, but 2 things hold me back: (1). I haven't soldered anything since my college days, and (2). the difficulting in procuring components (Audio grade capacitors, etc) in India.Buffalo DAC looks complex for a newbie DIY'er like me but will put my hands on it sometime.
Most CMoys kits come with all components, but there's no fun in DIY if you can't interchange & try different components, and sourcing the components that aren't in the kit won't be easy.
