hi folks,
i had recently picked up a 12 inch Sony Sub REALLY cheap. since i already have a sub in my car, i thought "why not use it at home... all ill need is a ported enclosure"
here how my last sunday went.
we worked out the dimensions and designed a ported box. it should be tuned at about 40~42hz.
this design is better because ill be using this just for the sake of it in my room using a low power amp. hence more SPL using low power, the better.
i have some pics to share
work on the box. good quality MDF (plus this guy does good work)
Tools we used to get the job done. thanks to a friend for getting them along.
The Port - made of PVC pipe from the nearby hardware store
the El Cheapo Woofer... JUST loud enough to shake my room loose...
and heres the final product!
got and its finally in my room.
as of now, i havent got an Amp yet. ill just get a regular cheap 2 channel amp or a low end second hand mono (just hook it up to my inverter battery and were good to go).
we tried it out in my room and even did the crawl to figure out the best location. will post few more pics once everything is in place.
cheers
cheers
