spirovious
He already has a bed, I think all that needs to be done is some minor rearranging.
Well Bed is filled with cotton,if you place nets with cotton inside can absorb better.
Rahul,
I can't thank you enough. It's not important how big or small the help is. The intent is important.
Hats off to you on figuring out my room size so correctly (it's 10'x11.5'). I am living in that room for more than an year and could never figure it out.
Your suggestion is apt, only issue I see is my listening position. If I put the bed exactly in middle, I don't have enough space to open the door (it opens inside).
But thanks anyways, it has given me quite an information. Let me try some other options.
Bizzare,
The placement for these speakers warrants a bit more of space from the wall, since they are rear ported. Placing away from the wall shall 'certainly' reduce the boomy feel you got. I face the same issue with my Quad Bookshelf speakers, they also are rear ported (The Air passage vent is behind the speaker).
Also you certainly need to play with the bass level if its provided, it will help getting the quality bass depending the situation of your room and since you cant move the speakers away from wall.
wishes
Couple things to note here.
From the sitting position the speakers appear low, so you wont get the proper effect during listening. THe speakers need to be raised.
to tame the boominess a bit, it would be worth a try to use some port plugs - thick sponge or pairs of socks rolled tight to plug the vents on the backs of the speakers. This also has the effect of quickly rolling off the bass tones to make music a bit more enjoyable.
Finally, use some dampers along the opposite edges of the walls as there is lots of reflection from the cement walls. I think you should look into room treatments a bit more.
All this unfortunately are band aid solutions to the problem. The big issue is that the speakers are the wrong choice for the room and setup. Sorry to be a downer but its a fact you have to keep in consideration re: what to expect out of your setup even if you change the positioning.
A good pair of bookshelves or wall mounts would have been a better choice.
