Need Articulating Tilt Swivel Plasma mount for 50 Inch TV
Thanks for input , it has single pivot arm , looking for something which has 2 arms for more stability and strength.
If you have a Chroma store nearby, please check with them. I bought one for INR 2000 but that's for a 32 inch LED. It says that it can hold upto 25 kgs so theoretically it shiuld be able to hold 50" as well.
Thanks for link .
Imported LCD LED TV Wall Mount Bracket Corner Swivel 37" 40" 42" 46" 60" 63" | eBay
The product looks nice and solid , can take upto 63 inch .
Is 5499 Rs reasonable price or is it costly ? .Any place I can pick up the same at lesser cost :o .If not I would buy this from ebay .
Honestly this looks expensive. I bought model 507 from SP road for Rs 1600. That too without bargaining. But if you feel product is good, it is a small price to pay for peach of mind. I bought it from Mangalam electronics
Thanks to kkdeep :clapping: .
I picked up the articulating swivel mount for 3400 Rs (without bill) from mangalam . This is same as this
The package was quite heavy ,good that I took the car ,it cannot be taken on bike .
I will mount it over weekend , lets c. Also picked up 6 high quality anchor blots (hiltz , i think ) , for wall mount , each costing around 27 rs .
Glad it worked out. where did you buy the anchor bolts from? Are the one coming with the mount not good enough? can you post some pictures of the anchor bolts?
Sorry for late reply , here are some pics .
