Need Help Audio Gurus Matching Speakers with Amps
rudraansh
India
Here is the configuration for a Small Cinema Theatre
L,C,R JBL 3722N, 400Watt@4ohms with crossover Quantity 3
SubWoofer JBL 3635, 300Watt@8ohms Quantity 1
Surround Speaker JBL8320 Cinema Surround,150 Watt@8ohms Quauntiy 8
Crown Amp Dsi-1000, 475Watt @4 ohms, 275Watt@8ohms Quantity 3
Now,
My 1 Amp is DSI-1000 with LCR has 75 watt more output
My 2 Amp Dsi-1000 with Subwoofer has 25 Watt less Output
Queries
Can this configuration blow my LCR Speaker.?
Can this configuration blow my SubWoofer.?
Is Using a more powerful amp than speaker is correct?
Can I take a chance using the above configuration?
Whats the next best thing i can do , without blowing the budget.
Regards to All Audio Gurus
Are you looking at a cinema hall or a home theater? The equipment you mentioned are all used by professionals for cinema halls and they usually have protection circuits built in.
In that case, you should consult with a professional. Most of the members here specialise in HT systems and audio systems. Though some of us may have knowledge in you area, it is always better to consult with a professional who has practical experience. As far as I am aware, powered speakers and the amplifiers used in cinema halls have protection circuits built in. Unless you really push them, it is very difficult to blow them.
