Need help finding Horn or Open Baffle Speakers
Rohit
I have heard Anil's as well as a couple of enclosures using Altecs, they sound good. I plan to do a small sub using a tapped horn design. In general horns are largish enclosures, so I am not too sure about how they will work in a small room. It is possible that there are small horn designs , though I dont know enough about them
Thanks George for the useful sharing!
Actually there are some smallish designs (like one built by soundnovice and one by satyaki) thye user the fostex 126en driver) They are standard FS dimensions.
Meanwhile I am educating myself more about these interesting designs.
Cheers!
Cheers!
Pls. PM me your email ID and i can share some informatiion on my Horn design.
@ Rohit,
I have mailed you a hybrid design consisting of an OB + Horn. The OB will cater to the lows and the Horn will take over for the mids and the highs. Do let me know if you will like to know more.
